Activity Forums Apple Final Cut Pro Legacy Direct To Disk Live Recording workflow
  • Direct To Disk Live Recording workflow
    Posted by Ric Christoferson on April 23, 2008 at 1:46 pm
    We edit with FCP Studio 2 and are looking at the nNovia QC Deck Digital Video Recorder.
    We want to record 4 cameras Isoed to disk and the rough cut switcher output.
    We would like to capture directed to hard drives as .mov files and then bring into Final Cut for editing.
    Has anyone had any success with live direct to disk recording and if so, what is your workflow and equipment?
    thanks for your reply.
    ric
    Tom Meegan replied 18 years, 4 months ago 4 Members · 3 Replies
  • Gary Adcock
    April 23, 2008 at 2:07 pm
    this is being done all the time,
    Zodiac was captured on set with dedicated recorders from S.two and then edited directly in FCP.
    The systems are currently expensive, one alternative is to use the IoHD and a laptop, however that requires a system for every camera, since mac’s can only handle one video track at a time.
    onset tools from RaveHD, S.Two, and Codex all make tools to handle the issues.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Nate Stephens
    April 23, 2008 at 2:28 pm
    Check out the Panasonic P2 line of cameras..
    What you describe is why I am investing in P2..
    4 x HPX500s SDI into Pansonics new 400 switcher and then recorded via firewire to a FCP MBP to sata mirrored drives. The Panasonic switcher has FW out.. To ISO the cameras add P@ cards to them…
    (4 x HVX200 with HD component to SDI converter boxes)
  • Tom Meegan
    April 23, 2008 at 2:55 pm
    Slightly off topic, but:
    https://www.telestream.net/products/pipeline.htm
    Saw this product at NAB. Allows 4 concurrent streams on a server AND you can start to edit in FCP while it continues to record. HD-SDI is not quite ready but they are working on it.
    You could correct mistakes in the live cut as the assistant director marked them by using multi-clip in FCP. Just make the main stream the director’s cut, and create your own switch as needed.
    If your budget is large, EVS servers support ProRes now. This solution is bullet-proof, but the price reflects that. The work flow is sweet.
    Best,
    Tom Meegan
