Activity Forums Adobe Premiere Pro Direct Link to Adobe Speed Grade breaking morph Cut
  • Direct Link to Adobe Speed Grade breaking morph Cut
    Posted by Austin Albert on June 19, 2015 at 6:20 pm
    Hey all,
    Been having an odd issue with morph cut and was wondering if it has been happening to other people and if there is a solution. I’m running the most up to date CC package with premiere and speed grade, and if I have a project file that I wish to take into adobe speed grade, it works just as it usually does, however when I go back to my premiere project after making my color corrections all of my morph cut effects seem to be broken by the switch in programs.
    This specific project I have about 10+ sequences and whenever I edit a single sequence in speed grade EVERY morph cut in the entire project reads “Failure: Can’t apply to a single clip.” And the only way I’ve found to fix this is to delete the morph cut and re-apply and re-render.
    I was wondering if anyone has any solutions on how to remedy this. Thanks in advance.
    Austin Albert
    Video Manager
    Save the Children, USA
    Naveen Mallikarjuna replied 11 years, 3 months ago 2 Members · 1 Reply
  • Naveen Mallikarjuna
    June 20, 2015 at 5:54 pm
    No solution, but just discovered I have the same problem. Mac OS X 10.10.2
    Not sure what OS you’re on but DirectLink from Pr to Sg actually does not work on a Mac. From Pr to Sg back to Pr the first time it’s fine. Go back into Sg and big problems. Just an FYI.
    Naveen
