Activity Forums Avid Media Composer Dire Straits!
  • Dire Straits!
    Posted by Shannon Bentley on September 23, 2009 at 2:33 am
    OK not the band…the position I’m in right now!
    Has anyone seen the error:
    Exception: FileInputOutput: GetAFileHdl – no I/O slot open…
    when you try to do an audio mixdown?
    I’m trying to make a tight deadline for a client and finished the sequence but when I go to do an audio mixdown, I get that error. I’ve exported this sequence several times before (for the client’s review) with no problem. What gives now???
    I tried bypassing the whole mixdown thing and went straight to export, but then it just totally freezes up when it gets 3/4 of the way through the AIFF.
    PLLLLEEEEAAAAAZZZEEEE tell me it’s a simple fix. I can’t lose this client!!! Thanks in advance for any insight or advice you can give me.
    Ed Cilley replied 17 years ago 4 Members · 4 Replies
  • Terence Curren
    September 23, 2009 at 4:15 am
    The 3/4s through thing gives you a clue where to look. Break down your sequence. Export the first third, then export the second third, etc until you find the offending section that won’t go out.
    My guess is you either have corrupt media or a corrupt audio effect.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Jon Zanone
    September 23, 2009 at 12:22 pm
    Fade to Black.
    The Dires Straits Song, not the effect.
    Also, check your Quicktime version. If you (or iTunes) have updated to far, you’ll get squirrely audio issues.
    You can check here for you MC version / OS / Quicktime version…
    https://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=267087
    Be curious, not judgmental.
    Walt Whitman
  • Shannon Bentley
    September 23, 2009 at 1:27 pm
    Thanks so much Terrence. That gives me a good place to start…track down that corrupt culprit and nix it. I’ll let you know how things turn out!
  • Ed Cilley
    September 23, 2009 at 2:16 pm
    Shannon,
    The other problem may lie in the sampling rate of the audio. Go the Timeline Fast Menu, Clip Text>Clip Resolutions. If there are different bit rates or sample rates, this can cause issues. If so, transcode the problem clip and reedit it into the sequence.
    Ed
    Avid and FCP Preditor
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
