Activity Forums Apple Final Cut Pro Legacy dip-to-color dissolve w/ letterboxes
  • dip-to-color dissolve w/ letterboxes
    Posted by Chris Gallaway on May 15, 2007 at 2:22 am
    I’m working in a 3:2 aspect ratio timeline with footage that is letterboxed. When I add a dip-to-color (i.e. white) dissolve between clips, the whole frame dissolves to white, including this letterboxed portion. How can I restrain the dissolve effect to occur only within the video portion of the frame (b/n the letterboxes)? When I bring the dissolve effect up in the viewer, it does not have the motion tab available where I could crop it, and I’m not able to apply the widescreen effect under “Effects/Matte/Widescreen.” There must be a way to make this work.
    Thanks, cg
    Chris Gallaway replied 19 years ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 15, 2007 at 2:23 am
    Nest the clips, then letterbox the nest.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Chris Gallaway
    May 16, 2007 at 2:38 am
