Activity › Forums › Avid Media Composer › DIO Runtime uninstall problem
  • DIO Runtime uninstall problem
    Posted by Scott Thomas on June 22, 2007 at 11:12 pm
    I am having problems opening Avid XP Pro 5.7 (it just hangs and doesn’t open). I have downloaded v 5.7.2 and installed it. But I need to replace the DIO runtime programme. I can’t uninstall it using add/delete programmes in Control Panel and ccleaner won’t get rid of it either. All I get is “setup.exe has encountered a problem…”
    I have dipped into the registry but I am not confident about deleting the right stuff.
    Can anyone offer any more advice for getting rid of this thing short of a clean Windows install (which ain’t gonna happen)?
    Thanks guys (and ladies).
    Pukkascott
    Scott Thomas replied 19 years, 3 months ago 1 Member · 1 Reply
  • Scott Thomas
    June 24, 2007 at 8:44 pm
    Follow up on the above.
    Did eventually delete the string in the Registry without destroying my laptop. Re-installed the DIO runtime and then uninstalled it the usual way.
    In fact this didn’t solve my problems with starting the Avid programme. It turned out to be a RAM problem – I had doubled the amount on my system and for some reason Avid XP Pro doesn’t like this.
    I have created another post to try and solve this problem so please use the link if you have a similar problem.
    Pukkascott
