Activity › Forums › Cinematography › Dimming a softbox
  • Dimming a softbox
    Posted by Dylan Hargreaves on December 29, 2012 at 12:26 pm
    Hey folks,
    I have a Photoflex Starlite softbox which is proving next to useless for 99% of the time I need it due it simply being too powerful.
    What solutions are there to dim one of these softboxes without causing the colour temperature to drop?
    Thanks in advance!
    D
    Mark Suszko replied 13 years, 8 months ago 4 Members · 4 Replies
  • Rick Wise
    December 29, 2012 at 7:35 pm
    I’m not sure what kind of lamp housing you are using with your soft box. Solutions: lamp with smaller (less wattage) lamp(s); add wire scrims in front of the bulb housing if possible; add ND sheets to the front of the unit.
    Rick Wise
    Cinematographer
    San Francisco Bay Area
    https://www.RickWiseDP.com
  • Todd Terry
    December 29, 2012 at 7:53 pm
    All of Rick’s suggestions are good ones.
    The easiest would be to use a different lamp. I wouldn’t use the “real” Starlite globe. If I recall they are 500w or 1000w clear glass bare bulbs. I believe they have a regular Edison screw-in base so it would be super easy to put a lower-wattage tungsten or CFL lamp in it.
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    fantasticplastic.com
  • Dylan Hargreaves
    December 30, 2012 at 2:02 pm
    Thanks both!
  • Mark Suszko
    December 31, 2012 at 8:55 pm
    And if you don’t have any of those, there’s always the square-cubed law…. though, the farther back you pull it, the more chances you need extra flagging to hold back any spill.
