Activity Forums Adobe Encore DVD Dimension problem importing avi
  • Dimension problem importing avi
    Posted by Dakota Joe on August 16, 2006 at 2:07 am
    I brought a PAL tiff sequence into AE 7 and wanted to convert it to NTSC. I created an NTSC comp and brought in the PAL file and collapsed it down to fit NTSC dimensions, turned on frame blend and rendered out as an uncompressed avi. But when I import it into Encore 2, the video is stretched out to the sides and a lot of the image is missing. This is not the case when I bring it into Premiere Pro 2. Is this an Encore problem or an After Effects problem?
    Thanks.
    BTW: This problem does not happen if I create a QT file.
    Dakota Joe replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
