Activity Forums Media 100 digitizing setting to maximize video quality
  • digitizing setting to maximize video quality
    Posted by Macmauro on April 30, 2006 at 2:05 pm
    Hi
    i shooted video in dvcam format; pal 720:576; 16:9 anamorphic
    using 2 pd 150 sony cameras (3ccd)
    at which quality i can digitize the video manteining the original video quality?
    i can arrive at 360kb per frame, but isn’t this more than the shooting quality?
    PS which sotware i can use to convert 4:3 to 16:9
    thanks a lot
    Maurizio
    Macmauro replied 20 years, 4 months ago 2 Members · 2 Replies
  • Floh Peters
    April 30, 2006 at 3:05 pm
    For online quality from DVCam I would suggest something around 240k PAL. DVCam data rates are lower than that, but since the signal gets converted to uncompressed and then recompressed to the Media 100 i codec it makes sense to keep the data rate higher. On recompression artifacts could appear when using lower data rates.
    [macmauro] “PS which sotware i can use to convert 4:3 to 16:9”
    E.g. AfterEffects. Or Media 100 sw, which is quite good at mixing 4:3 and 16:9 material.
  • Macmauro
    April 30, 2006 at 5:31 pm
    thank you Floh
    excellent as always
    M.
