Activity Forums Apple Final Cut Pro Legacy Digitizing HD footage using Canon HV20
  • Digitizing HD footage using Canon HV20
    Posted by Jessica Buritica on January 18, 2010 at 5:19 am
    Im working with FCP 6.0.5. trying to digitize HD footage recorded with a Canon HV20 Camera. Im trying to digitize using the camera with a Firewire 400 cable. Using Device control DVCPRO HD FIREWIRE and Capture settings set to DVCPRO HD 1080i60.
    I changed Camera setting AV-DV to ON. was able to get a ‘VTR OK’ signal on my FCP Log and Capture screen, Also able to control camera playback wtih FCP. Not able to obtain a video preview however, and whether I log a clip first or do Capture NOW…the camera plays back but nothing records on FCP. nor does anything appear on screen.
    Any troubleshooting suggestions are greatly appreciated!
    Andrew Kimery replied 16 years, 8 months ago 5 Members · 6 Replies
  • Zane Barker
    January 18, 2010 at 5:31 am
    [Jessica Buritica] “trying to digitize HD footage recorded with a Canon HV20 Camera”
    [Jessica Buritica] “Capture settings set to DVCPRO HD 1080i60. “
    Never used that camera but a 2 second search tells me that it shots HDV
    https://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=177&modelid=14869#ModelTechSpecsAct
    You cannot capture HDV footage using DVCPRO HD Settings using firewire.
    Ether select the appropriate HDV capture settings or capture via prores.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Jessica Buritica
    January 18, 2010 at 5:35 am
    DVCPRO HD FIREWIRE, for some strange reason, was the only preset that was giving me control over the camera playback. All the others set me back to no communication. Could that have been FCP getting glitchy?
  • Zane Barker
    January 18, 2010 at 5:36 am
    Trash your FCP preferences, repair permissions and restart.
  • Shawn Bann
    January 18, 2010 at 6:45 am
    also-
    sometimes you have to close and relaunch FCP, depending when you connected your camera.
    shawn
  • Neil Sadwelkar
    January 18, 2010 at 7:50 am
    Also ensure the tape was actually shot HDV not DV.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Andrew Kimery
    January 18, 2010 at 4:25 pm
    [Jessica Buritica] “I changed Camera setting AV-DV to ON”
    I believe by doing this you are down converting the signal coming out of the camera to DV instead of sending out HDV. This would explain why the DVCPro HD Easy Setup allows you to control the camera because DV and DVCPro HD use the same deck control protocol.
    -A
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
