Activity Forums Apple Final Cut Pro Legacy digitizing DVDs (of my own work)
  • digitizing DVDs (of my own work)
    Posted by Brian Lindstrom on September 29, 2009 at 5:30 pm
    Hi All:
    I need to make a demo reel pronto. Is there a way I can digitize DVDs of my documentaries (and thus avoid the expense of going to an edit house to work from Beta SP)? When I try to import the DVD, it immediately opens up with DVD player and I’m unable to select it for import.
    Brian
    Walter Biscardi replied 16 years, 11 months ago 8 Members · 16 Replies
  • 16 Replies
  • Andrew Brose
    September 29, 2009 at 5:46 pm
    Brian,
    MPEG Streamclip is an excellent freeware program you can download for this particular application. Once you’ve installed the software, open your DVD and export your project to almost any format. The program is quite straight forward and simple to use.
    Good Luck!
    Andrew
  • Joey Burnham
    September 29, 2009 at 5:54 pm
  • David Bogie
    September 29, 2009 at 7:07 pm
    the easiest way to get DVD content into FCP is to hook the outputs of a DVD player to the inputs of DV camcorder or deck and come in via Firewire. Everything else is a PITA.
    bogiesan
  • David Roth weiss
    September 29, 2009 at 7:29 pm
    [david bogie] “the easiest way to get DVD content into FCP is to hook the outputs of a DVD player to the inputs of DV camcorder or deck and come in via Firewire. Everything else is a PITA.”
    Sorry Bogiesan, but ripping a DVD with Streamclip is faster than realtime and requires no cable or camera hookup. So, exactly how does analog capture qualify as “easiest?” It’s certainly not faster.
    The only value I can see might be if you have only a tiny clip or two and you determine it might be faster just to capture those shorties as opposed to ripping the entire DVD or VOB.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Joey Burnham
    September 29, 2009 at 7:35 pm
    Plus you can mark an in and out in streamclip. U don’t have to rip the whole disk
  • Alan Okey
    September 29, 2009 at 8:36 pm
    [David Roth Weiss] “Sorry Bogiesan, but ripping a DVD with Streamclip is faster than realtime and requires no cable or camera hookup. So, exactly how does analog capture qualify as “easiest?” It’s certainly not faster. “
    It sort of reminds me of someone sticking a microphone in front of a stereo to record a vinyl LP onto tape, or setting up a camera to shoot a TV screen to record something off of the air. Definitely the long way around, and far from the best quality.
  • David Roth weiss
    September 29, 2009 at 8:44 pm
    [Alan Okey] “the long way around, and far from the best quality.”
    And, you’d think that anyone who rides a recumbent bicycle would be looking outside the old analog box…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Joey Burnham
    September 29, 2009 at 9:03 pm
    Do you think the video takes a quality hit by running it through streamclip as opposed to analog? Streamclip is just unmuxing the files and exporting to whatever codec you choose. How is analog any better? The files are already compressed.
    Just curious.
    Joey
  • Greg Ball
    September 29, 2009 at 9:07 pm
    Video quality will be MUCH higher through streamclip than an analog cable.
    Just make sure you have the write codec selected for the timeline sequence you’re editing in.
  • Brian Lindstrom
    September 29, 2009 at 10:41 pm
    Andrew:
    Worked like a charm!
    Thanks so much!
    Best,
    Brian
