Activity Forums Event Videographers Digitizing Deck Terminology and Recommendations
  • Digitizing Deck Terminology and Recommendations
    Posted by Justin Whitney on May 19, 2010 at 5:16 pm
    First of all, my apologies – I’m quite sure this question has been answered and that this is probably the wrong forum. But this is one of those cases where I don’t know enough even to formulate the question, much less to google it myself.
    I’ve seen and worked with high-speed digitizing decks for mini-DV and combo decks that add a VHS bay but I have no idea the make and model of them. What is the correct terminology for these decks (I’m thinking “high speed digitizers” isn’t quite right)? And second, where should I start looking for prosumer and pro grade decks? I’m going to be digitizing VHS tapes on an ongoing basis but the Best Buy gadgets that you plug into a VCR don’t quite make the grade.
    Thanks. And please don’t bite the newbie.
    Mark Suszko replied 16 years, 4 months ago 2 Members · 1 Reply
  • Mark Suszko
    May 19, 2010 at 10:18 pm
    The only faster-than-real-time DV dubbing unit I’d ever heard of was a special computer-based drive Panasonic used to make for their NLE systems, that could ingest/import a DVC pro tape for editing at twice real time speed. it was expensive at the time and only worked with DVC Pro tapes. I used to work with high-speed audio dubbers for reel-to-reel and audiocassette tape long ago when you cut tape with a Gillete single-edged razor blade… but have never laid eyes on a video version of these. I guess I gotta get out more often:-)
    I have a DVD/VHS combo unit at home that dubs bi-directionally, but only in real time. At work, we have DVD duplicator towers that will do high-speed DVD dubs, from a DVD master, ten at a time, in about 2 minutes per run.
    But I’m unfamilar with what you’re describing here, sorry.
