Activity › Forums › Apple Final Cut Pro Legacy › Digitizing Betacam tapes with FCP7
  • Digitizing Betacam tapes with FCP7
    Posted by Jeff Cadge on December 1, 2011 at 2:57 am
    Hello,
    We’ve been working almost entirely tapeless with P2HD and FCP7 with a solid workflow.
    A client gave us a bunch of Betacam master tapes to digitize into FCP using our Kona LH and wonder what setting you guys use for the best results.
    We did a couple of tests:
    525 29.97 ProRes HQ resulting in a 720×486 file that is choppy in playback with a size of about 600 MB/min
    525 29.97 8 bit resulting in a 720×486 file which is clean but a larger file size of about 1.2 GB/min
    Any ideas which settings would provide the best results without producing huge files?
    We have a lot of Betacam masters to digitize.
    Thanks for your help.
    Jeff Cadge
    Daryl Larson replied 14 years, 9 months ago 5 Members · 4 Replies
  • Steve Eisen
    December 1, 2011 at 4:40 am
    Standard ProRes is the perfect setting. HQ is overkill!
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Kevin Rag
    December 1, 2011 at 8:19 am
    I agree with Steve. ProRes 422 is the way to go.
    Kannan Raghavan
    The Big Toad Films Pte. Ltd.
  • Chris Tompkins
    December 1, 2011 at 1:09 pm
    Make sure you are playing back the media off drives for video editing…
    Chris Tompkins
    Video Atlanta LLC
  • Daryl Larson
    December 20, 2011 at 9:01 pm
    I have done a bunch of work with Betacam tapes and Kona cards. Never had any problems with playback-we use an XSAN storage system so file size really doesn’t matter to us…
    I have also used a Matrox MX02 system to digitize natively to Apple Pro Res (not HQ) and the resolution has been good. Playback was off of FireWire 800 & 400 HDs and we had no problems. File sizes were big but not as big as APR HQ files (which did not playback well from FW).
    I would try regular APR instead of HQ.
    Caveat: the source footage I have been working with is old and in some cases not the greatest, so all I can say is that the APR footage did not look any worse than the original.
    Gryfwalker
