Activity Forums Apple Final Cut Pro Legacy digitizing beta – field order?
  • digitizing beta – field order?
    Posted by Jason Brown on December 17, 2010 at 4:02 am
    Hey Guys,
    I’m going to pull in Betacam via MXO2 – curious about the field order setting.
    Is the field order determined when you shoot? Or when you digitize?
    The camera is an Ikegami HL-45W shot @ 720×486 anamorphic.
    I know on an AVID Meridien that I used to work on, the field order was Lower Field First.
    -Jason
    Jason Brown replied 15 years, 8 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    December 17, 2010 at 4:11 am
    All Sd codecs in FCP that are NTSC are lower field first. You capture card should take care of it if you use an easy setup.
    jeremy
  • Jason Brown
    December 17, 2010 at 4:17 am
    sweet…thanks Jeremy!
  • Jeremy Garchow
    December 17, 2010 at 5:37 am
    That’s why I said in FCP.
    640×480 in m100 is hardly the latest/greatest in digital land. If you have a “modern” capture card and are capturing NTSC video in to Fcp using apple codecs, it’s going to be LFF. Better?
  • Jeremy Garchow
    December 17, 2010 at 6:37 am
    Uh. Ok. It’s 2011. You would use something like OP is using that would capture to a LFF codec in SD/NTSC
    Thats all I’m saying.
    640×480 uff does not fit, although I appreciate your reminiscence of the old days.
    They are gone. Unless you keep your Quadra around and capture to m100 to edit in FCP?
    Come on dude. I know you dont.
  • Rafael Amador
    December 17, 2010 at 9:41 am
    [Jason Brown] “Is the field order determined when you shoot? Or when you digitize?
    The camera is an Ikegami HL-45W shot @ 720×486 anamorphic.”
    In ALL analog format the “odd” fields are laid first .
    So they would be de equivalent of UPPER FIRST.
    When you digitize that analog picture, the field order you get, will depend of the Codec you choose.
    Being in NTSC, all your capture options are codecs Lower-first: DV, DV50, 8/10b Unc, etc.
    In Pal land would be different, with all the DV options Lower first, and all the 8/10b options Upper-first.
    rafael
    http://www.nagavideo.com
  • Jason Brown
    December 23, 2010 at 2:05 pm
    Just a thought I had this morning. I’ve not ever done any “up-converting” of footage with my Matrox. Would this be a good opportunity to do that? It will be coming into the Matrox through SDI and it’s 16×9 SD.
    Are there quality advantages to upconverting? Or is it a workflow benefit when mixing with HD sources?
    -Jason
