Activity › Forums › Apple Final Cut Pro Legacy › Digitizing 24p footage from HVX
  • Digitizing 24p footage from HVX
    Posted by Adam Davis on June 7, 2008 at 6:05 pm
    I just shot a project on an HVX in 24p, 480 interlaced, 4X3 letterboxed. I’m editing on FCP HD.
    How should my capture and sequence settings be configured so it captures correctly?
    Thanks for your help.
    Captain Mench replied 18 years, 3 months ago 2 Members · 3 Replies
  • Captain Mench
    June 7, 2008 at 7:48 pm
    If it is 24p it isn’t interlaced…. it is combined – there is a difference.
    So…
    Just capture using a simple easy setup 29.97 DV/NTSC setting.
    You’ll get 3 progressive and 2 combined frames every 5. That’s what 24p means. (kinda)
    Good luck,
    CaptM
  • Adam Davis
    June 7, 2008 at 8:34 pm
    Thanks for the info. So should I edit in a 23.98/24fps sequence, or just the regular 29.97?
  • Captain Mench
    June 8, 2008 at 1:09 am
    The regular 29.97.
    If you want to go to 23.98 you should have shot in 24pA… however, you CAN use Cinema Tools to remove the 3.2 cadence and edit in 24fps.
    Check the manual in CT for how.
    CaptM
