Activity › Forums › Apple Final Cut Pro Legacy › Digitizing 24 Channels
Posted by Tim Counihan on June 24, 2006 at 4:34 amHey everyone,
Does anybody have any experience digitizing multiple audio tracks (24). The documentation says with proper hardware you can acheive this. Does this hardware exist??
Thanks for help,
Tim
Walter Biscardi replied 20 years, 2 months ago 5 Members · 4 Replies -
Tom Wolsky
June 24, 2006 at 4:44 amI don’t think the documentation actually says that. You can capture and export up to eight tracks in hardware. FCP supports up to 24 tracks for a clip, or 24 tracks on export to software, but not to hardware.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
Mark Raudonis
June 24, 2006 at 5:00 amMulti-track audio is mostly “imported” not “Digitized”. Do a google search on “Broadcast Wave Files”.
mark
Martin Baker
June 24, 2006 at 11:33 amUp to 24 channel audio capture is supported in FCP5. Most capture cards support up to 8 channels of embedded audio through SDI (though Kona 3 offers up to 16 channels of embedded). I’m not aware of any capture cards which offer more than 8 AES or analogue inputs.
So depending on how many channels you want to capture, the other possibility is to use a separate audio interface such as MOTU or RME. If the interface has Core Audio drivers available then it should appear as a device in FCP’s Capture Preset Editor. There may be A/V sync issues with this method although if you can genlock the audio interface then I would imagine it would work fine.
I doubt there is anyone who has ever tried this but in theory it would work.
Martin
Digital Heaven, London UK
Unique plug-ins and tools for Apple Pro Apps
NEW! BigTIme – resizable timecode display for FCP -
Walter Biscardi
June 24, 2006 at 3:07 pm[Tom Wolsky] “You can capture and export up to eight tracks in hardware. FCP supports up to 24 tracks for a clip, or 24 tracks on export to software, but not to hardware.”
Kona 3 allows up to 16 tracks of audio during capture. I have it installed and it immediately opened up 16 channels in the Log and Capture window.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
