Activity › Forums › Apple Final Cut Pro Legacy › Digitize through broken time code?
  • Digitize through broken time code?
    Posted by Chad Treanor on January 15, 2006 at 3:39 am
    I’m digitizing lots of miniDV tapes on a G5 with FCP 4.5 on it.
    Now oddly enough the producers and directors from this program shot the video with Time of Day time-code. so literally everytime they stopped and started recording theres new timecode (and according to FCP: a timecode BREAK). I’ve been going through and letting the video crash dig. in and letting FCP rename the clips in numerical order. I know for a fact that I can dig. through broken time-code on my premiere system.
    Is there a digitizing setting I can change to crash digitize through broken time code? If so I will crash in ten minute chunks at a time.
    Any response is welcome,
    Thanks in advance,
    CH4D
    Arnie Schlissel replied 20 years, 8 months ago 6 Members · 6 Replies
  • Dan Riley
    January 15, 2006 at 5:04 am
    NO NO NO.
    Do not crash digitize. This is not something that’s unique to FCP.
    AVID and any Pro edit system is the same. You need to playback
    your tape and log/name each scene. This is how any good editor
    would do it. This makes for much faster editing.
    Then you batch digitize all your logged scenes.
    Dan
  • Shane Ross
    January 15, 2006 at 5:13 am
    Do what Dan says. Time code is EXTREMELY important, so don’t capture in a way that will cause you to lose that information. LOG & CAPTURE…that is the way professionals do it, and it way it is expected to be done. Makes the capture process longer, but the edit process quicker.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Pol
    January 15, 2006 at 11:34 am
    I’v had a simular situation. If it’s possible copy the tapes with new timecode.
  • Shane Ross
    January 15, 2006 at 11:54 am
    I fail to see what is wrong with logging and capturing…
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Walter Biscardi
    January 15, 2006 at 12:21 pm
    Sure there’s settings in the User Preferences that tell FCP what to do when it hits a TC break.
    You may want to try Logging large chunks of the tape at a time and set FCP to “Create a New Clip” at each TC break. This will take much longer than just crash digitizing, but without TimeCode, you’ll never be able to bring the project back at a later date.
    If you do to ahead and log each and every timecode break, be sure to leave enough pre-roll at the beginning of each logged clip to allow the VTR to cue up.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Arnie Schlissel
    January 15, 2006 at 7:13 pm
    [Shane Ross] “I fail to see what is wrong with logging and capturing…”
    The same thing that’s wrong with obeying fire codes, building codes, worker safety codes when building a sky scraper- it takes longer & costs more to do it right than it does to cut corners. Until, that is, your job site is shut down by an accident.
    Arnie
    https://www.arniepix.com
