Activity › Forums › Apple Final Cut Pro Legacy › Digitize Issues
  • Digitize Issues
    Posted by Earle Nichol on June 19, 2008 at 10:54 pm
    Hey Gang,
    This may be something I have to live with, but I just want to see how everyone else is handling the following issue:
    We are cutting a series that is shooting “time of Day T/C”. We are digitizing from a Panasonic AJ-HD1400 HDSDI thru a Kona 3 into FCP Studio 2. Because there is so much footage, we just digitize from start of tape “Digitize Now”. When a T/C break happens we have the FCP set up to make a new clip. The problem is it takes for ever for the deck to find the T/C break and then pre roll for the next clip.
    This is wearing my heads out on the deck! Is this just inherant with FCP or do I need to use a AJHD 1700? Babysitting the digitizing is very inefficient. Any thoughts??
    thanks
    Pearl
    Communication, Communication, Communication!!!
    http://www.whiteiron.tv/demo
    Earle Nichol replied 18 years, 3 months ago 3 Members · 3 Replies
  • Chris Borjis
    June 19, 2008 at 11:42 pm
    Time code breaks make it impossible to batch.
    if you are doing “capture now” you must switch
    the deck control in fcp to “non-controllable device”
    otherwise it does that which you are experiencing.
  • Eric Johnson
    June 19, 2008 at 11:47 pm
    If you go into the “User Settings” in the FCP drop down, change how FCP deals with a TC break to warn after capture, then you’ll have just one clip that you can subclip. It will be faster and easier on your deck, but just as time consuming.
    As far as one deck being faster than the other, the higher end deck ideally would be faster, but finding the exact frame of the TC break and doing the pre-roll is just plain time consuming.
    If you need multiple clips, have your shooters take note of when they start and stop the camera and do a very quick log of the tape and let it roll after you get to the end of the tape.
    If you do the later of the options you can just set it and forget it, because the breaks should be a null issue.
    All options will take some of your time the later should take the least.
  • Earle Nichol
    June 20, 2008 at 4:15 pm
    Hey Guys thanks for the input….I’ll give your suggestions a shot, and get back to.
    Appreciate your time.
    pearl
