Activity Forums Apple Final Cut Pro Legacy digitize bug in FCP 7?
  • digitize bug in FCP 7?
    Posted by Michael Williams on January 6, 2010 at 9:09 pm
    Just starting to work in FCP 7 and have come across something that seems to be a bug after quite a bit of troubleshooting. curious if anyone else is experiencing the same issue.
    When logging and capturing from tape, everything works fine unless I close the log & capture window and then batch capture clips from the browser. When it begins the capture, it stops and says “general error.” It will not work again unless I do a restart. If I keep the log & capture window open and continue to digitize, it does not occur.
    So far, this is not a big problem and I have been able to work, but would like to know if there is something that could eliminate the problem.
    thanks,
    mvw
    Michael V. Williams
    producer/editor
    http://www.vernonvision.com
    Michael Williams replied 16 years, 7 months ago 2 Members · 2 Replies
