Activity Forums Apple Final Cut Pro Legacy Digitising DV CAM tape
  • Digitising DV CAM tape
    Posted by Rich Franklin on July 9, 2011 at 9:55 am
    I have some DVCAM tape that needs to be digitised so that I can edit it in FCP. What is the best format to save it as so that I can import it into FCP. Maximum quality needs to be retained as the final video will be played on a DVD/Television.
    Thank you
    Chris Tompkins replied 15 years, 2 months ago 3 Members · 2 Replies
  • Steve Eisen
    July 9, 2011 at 2:42 pm
    choose DV/NTSC in easy setup. Use log and capture. Your quality will not improve if you try to convert to another codec.
    As I told you before, garbage in garbage out applies.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Chris Tompkins
    July 9, 2011 at 3:16 pm
    DVCAM Deck w/ a FW port.
    Like Steve says, Easy Setup DV
    Chris Tompkins
    Video Atlanta LLC
