Digitised M100HD media import into M100i
Posted by Peter Stewart on December 28, 2005 at 4:57 pmHi,
I’ve digitised some footage using M100HD (v10.1.2) from a digibeta deck for use on a M100i system (v8.2.2), but when I try importing the media into M100i all I get is black video (on the record monitor and on the video monitor).
Does anyone else have this problem and know if there’s anything I can do to solve it?
Peter
Peter Stewart replied 20 years, 4 months ago 4 Members · 6 Replies -
Matt Short
December 28, 2005 at 5:53 pmI believe you have to export from HD using the M100i codec before importing into M100i.
Peter Stewart
December 28, 2005 at 8:45 pmq[matt short] “I believe you have to export from HD using the M100i codec before importing into M100i.”
Thanks for the reply Matt.
I was hoping to keep the timecode with the media file.
It was digitised with the m100i codec.
I forgot to say it opened on the m100i system in quicktime player and played out to the video monitor ok, was only black once in m100 itself.
Peter
Matt Short
December 29, 2005 at 12:46 pm[Blue Peter] “I forgot to say it opened on the m100i system in quicktime player and played out to the video monitor ok, was only black once in m100 itself.”
It will play in quicktime because you have the Media100 codec but, any files created or imported into HD or SW cannot go into M100i without exporting them first. This quote is from the M100 website…
“Media 100 sw will be able to open any program created on Media 100i and continue editing. Your Media 100i system will not be able to play a program created on Media 100 sw, but the QuickTime media exported from Media 100 sw will be able to be imported and played out to tape on Media 100i.”
The same applies to HD.
HTH
Matt -
Warren Eig
December 29, 2005 at 4:24 pmCould you not simply export an EDL, import the EDL into Media 100i and relink the media files?
Warren
Floh Peters
December 29, 2005 at 4:43 pm[Warren] “Could you not simply export an EDL, import the EDL into Media 100i and relink the media files?”
No, you cannot relink media based on an EDL. You would need to redigitize.
Peter Stewart
December 29, 2005 at 4:53 pmI’m not using M100sw.
I got the same media files (from HD) to work fine on a third M100i, but still not on the system I want to use.
