Activity Forums Avid Media Composer Digitise options
  • Digitise options
    Posted by Michael Thomson on July 7, 2005 at 8:10 am
    Hi guys/gals
    Anyone know if you can digitise interlaced footage taking only 1 field. You can do this in some NLE’s using a draft mode selection at digitise.
    I dont mean to do this with a single field res, more to be able to do it at 1:1.
    Any ideas?
    Cheers
    Michael Thomson replied 21 years, 2 months ago 2 Members · 2 Replies
  • Paul Ingvarsson
    July 7, 2005 at 12:52 pm
    So you want to digitise a single field – but don’t want to digitise single field res?? I’m not following.
    Some avids can digitise 2:1s – but i guess that’s not what you want?
    You could digitise at 1:1 then drop motion effects on your clips to set them to duplicate field at 100% speed. You could also digitise through a Snell and Wilcox ARC100 with the film mode setup – that gives you frame based footage from interlaced footage. There is a 2 frame video signal delay to deal with here, but the results will be much, much better than a simple field strip – however you do it.
    Paul
  • Michael Thomson
    July 7, 2005 at 1:54 pm
    Cheers Paul.
    I will have a look at those options
