Activity › Forums › Apple Final Cut Pro › Digitise old S-VHS Tapes
  • Digitise old S-VHS Tapes
    Posted by Nevile James on July 17, 2018 at 6:16 am
    I have been digitising some old S-VHS tapes using Final Cut Pro 5 for a couple of years.
    This morning, the system just doesn’t work – I just get a “Preview Disabled” message.
    The S-VHS recorder is working fine and the Sony DSR-25 is producing an output (checked on a much more modern machine).
    Nortynev
    Jeremy Garchow replied 8 years, 2 months ago 2 Members · 5 Replies
  • Jeremy Garchow
    July 17, 2018 at 11:43 am
    Try trashing preferences.
  • Nevile James
    July 17, 2018 at 3:06 pm
    Thanks for the response – are you able to give me the path of the file?
    Nortynev
  • Jeremy Garchow
    July 17, 2018 at 3:59 pm
    It’s been a really long time since FCP5.
    Hopefully this will help: https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    But you have to hold option and use the “Go” menu from Finder to get to your Library folder.
  • Nevile James
    July 19, 2018 at 2:54 pm
    Unfortunately, I cannot get it to work.
    I have given up, and am now capturing the videos through Quicktime on a iMac.
    Thanks for your suggestions.
    Nortynev
  • Jeremy Garchow
    July 19, 2018 at 5:01 pm
    Did you try reelecting the DV easy setup?
    I believe you this control-q, and choose the DV easy setup. The DV deck has to be on and plugged in to firewire before launching FCP5.
    Wow, this brings back so many memories! 🙂
