Activity Forums Adobe Premiere Pro digitise across tc breaks
  • digitise across tc breaks
    Posted by Frédéric on October 11, 2007 at 3:33 pm
    I have rushes with real time tc – so this means tc breaks with each shot
    when digitising ppro seems to ignore those tc breaks and digitises with continuos tc – so with a wrong tc
    is there a setting somewhere that i didn’t find to digitise as separate clips with each tc break – or to at least digitise with right tc from the tape?
    thx, F
    Frédéric replied 18 years, 11 months ago 2 Members · 2 Replies
  • Baz Leffler
    October 12, 2007 at 12:50 am
    Unfortunately Adobe Premiere is not professional enough to recognise the fact that there are timecode breaks in a tape. Especially in the work flow that you are trying to use! You have to find workarounds – my workaround is to use FCP when I have that work model which IS pro enough to consider timecode breaks.
    Are you capturing it as DV?
    Baz
  • Frédéric
    October 12, 2007 at 7:06 pm
    Thx for the reaction Baz – i don’t believe a lot of real pro’s are working with ppro – and i’m beginning to understand why
    ppro is a good finisching tool but to edit in a real pro world – stinks
    so i’ll go to my fcpro – i’m digitising via sdi with serial remote – in fcpro i suppose i will go to an offline dv codec
    thx. Fr
