Activity Forums Apple Final Cut Pro Legacy Digital zoom within a PIP – how?
  • Digital zoom within a PIP – how?
    Posted by David Esp on August 31, 2009 at 12:26 pm
    I managed to use FCP’s Motion tab to create an arrangement of Pictures-In-Picture (PIPs). The arrangement consists of: a (large) PowerPoint image area, a video clip area (for clips of the presenter) and a text area.
    Now I want to digitally zoom/pan around the video PIP. I imagine I need to apply the Motion tab again somehow but how do I do this when it resizes the size/position of the PIP itself in the arrangement, rather than just digitally zooming the image within it as I require? I tried applying Motion (tab) as a second stage via a separate Sequence but still Motion tab adjustments in the Sequence affected the size/position of a PIP based on that sequence (as an item in the timeline).
    Is there a way out of this? Like making the sequence more independent somehow or by employing another method apart from Motion tab in FCP?
    Reason for wanting to zoom within a PIP: the video of the presenter was shot in HD and I want to re-frame him. The target medium is lower-res than HD and the PIP is of course even lower res, so there should be plenty of scope in principle.
    John Fishback
    replied 17 years ago
    3 Members · 3 Replies
  • Tom Wolsky
    August 31, 2009 at 12:41 pm
    Put the PIP image into its own sequence. Place the nest in the final sequence. Scale and position the PIP as needed. Go inside the nested sequence to adjust the scaling and positioning of the presenter.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • David Esp
    August 31, 2009 at 8:39 pm
    Thanks Tom, it worked fine. Not sure what I did wrong before, but I guess I was just more awake this time.
  • John Fishback
    September 13, 2009 at 10:39 pm
    If you’re going to do a lot of this checkout Digital Heaven’s Box plugin. https://www.digital-heaven.co.uk/dh_box
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
