Activity › Forums › Apple Final Cut Pro Legacy › Digital Watermark?
Digital Watermark?
Posted by Kevin Reiner on January 17, 2008 at 6:03 pmA new client asked if we can add a digital watermark to their spots for tracking purposes. We normally just deliver via BetaSP. I am guessing this is a bit of metadata added to a digital file. Is this something FCP can do, or should I just outsource it?
I am guessing the later.
KevinMartti Ekstrand replied 18 years, 7 months ago 3 Members · 3 Replies -
Don Greening
January 17, 2008 at 7:00 pmNormally a water mark is something like a company logo superimposed over the picture in one of the corners of the frame. Most often in the lower right corner. Unless a digital watermark is different than a regular picture watermark. Perhaps you’d best check with your client to confirm what they want. There are tutorials available that make picture watermarks an easy job.
If your client just wants copyright text, creation dates etc. you can easily add that within QT Pro.
– Don
Kevin Reiner
January 17, 2008 at 7:31 pmThanks Don,
What you speak of is the typical graphical watermark that I am familiar with, but I guess there is some newfangled thing called a digital watermark. Leave it to the video industry to give the same name to 2 different things 😉
I found someone who can do it for us. It is pretty much a signal embedded into the digital file that allows for tracking a spot and measuring it’s impact. I have 1 spot that is going to 40 different markets. I guess this helps them track its performance in different cities and demographics.
Does anyone know if FCP can embed a digital watermark? Or some other product? This is a new big client and if it is something that is worth the cost, I wouldn’t mind bringing it in-house.
KevinSystem Setup (for a more detailed list, see my profile)
HARDWARE
Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
9GB Memory
Two 16x SuperDrives
Dual-channel 2Gb Fibre Channel PCI Express card
Apple Cinema HD Display (23″ flat panel)
ATI Radeon X1900 XT Graphics Card
AJA Kona LHe SD/HD capture card
Apple Xserve Raid 5.6TBSOFTWARE
Mac OS X 10.4.10
Final Cut Pro Studio
After Effects CS3
Photoshop CS3
Illustrator CS3
Boris Continuum
Sapphire Plug Ins
Roxio Toast
Digital Anarchy Anarchist Suite
ParticleIllusion 3.0
Trapcode
Zaxwerks -
Martti Ekstrand
January 18, 2008 at 9:17 amMy guess is that your client is asking for a steganography mark, IE; something embedded in the image that will remain even outside the digital domain. You have it in Photoshop > Filters > Digimark but I haven’t seen any plug for FCP nor After Effects. Of course you could make a image sequence and do it in PS but I’d ask them for exact specifications. General info here:
https://en.wikipedia.org/wiki/Digital_watermarking
cheers
