Activity Forums Adobe After Effects Digital Juice Compositor’s Toolkit – Removing BGs
  • Digital Juice Compositor’s Toolkit – Removing BGs
    Posted by Dustin Alcock on January 27, 2009 at 4:44 pm
    Hi, I’m working with Digital Juice Compositor’s Toolkit using the Destructive Elements section and can’t figure out how to remove the black background to just leave the debris falling. In all their tutorials, they mainly use smoke or fire and just use screen mode but that makes the objects see through. I want the objects to be falling on the scene I shot instead looking real, not faded.
    Sadly their forums are pretty dead and their tech help is out sourced it sounded like so they were of no help.
    Thanks.
    Adi Mona replied 17 years, 7 months ago 5 Members · 6 Replies
  • Dustin Alcock
    January 27, 2009 at 5:09 pm
    How? I right click on the track in the project bin and go to interpret footage>main but the Alpha section is all grayed out. I think this is what I need?
  • Dustin Alcock
    January 27, 2009 at 5:47 pm
    Okay wow…thanks but to get the first thing out of the way, I’m new at all this. So it’s not that I “only read half” it’s that I only half understand.
    I’ll check it out, thanks.
  • Thad Ciechanowski
    January 27, 2009 at 9:43 pm
    You could also duplicate the layer and use it as a track matte.
    http://www.dijitmedia.com
  • Matthieu Foulet
    January 27, 2009 at 10:24 pm
    When you are using DJ footage, you have to use their Juicer application in order to render out the files correctly.
    In the output settings of this app, you have 4 available options to render Alpha
    if you render with embedded alpha, the black background will then automatically be removed inside AE.
    MacPro 8Core 2.8Ghz (january2008) //
    12GB OWC RAM //
    NVIDIA 8800GT 512Mb //
    OS X.5.5 (upgrading to X.5.6 made firefox, mail and safari unstable)
  • Roland R. kahlenberg
    January 28, 2009 at 6:05 am
    Use XMult to create an Alpha CHannel. Link –Xmult
    Cheers
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available)
  • Adi Mona
    January 31, 2009 at 4:25 pm
    For each clip you should have a provided matte
    lets just say you’ve got 0001_DElement.mov and 0001_DElement_Matte.mov
    Just import both clips into AE,
    drop them both into the timeline (With matte on top) and hide the Matte layer
    from the effects menu go to “channels” and add “Set Matte” to the original clip
    In the Effects Control window (for the original clip) set the “Take Matte From Layer” to your matte clip 0001_DElement_Matte.mov
    and Finlay Set “Use For Matte” to “Luminance”.
    I hope this can help.
