Activity Forums VEGAS Pro Digital Images and Audio Sync Problem Using Preview Display
  • Digital Images and Audio Sync Problem Using Preview Display
    Posted by Danenew on May 6, 2006 at 6:08 pm
    I am having difficulty consistently keeping images in sync with the audio track in the preview display. If I start and play at the location where the image and audio were out of sync, they will work fine. NOTE: I am not having any problem rendering. Below are my system specs.
    Processor: 3.0 GHZ
    RAM: 3 Gig
    Hard Drives: SATA 80 Gig & SATA 120 Gig
    Video Card: Nvidia Quadro 500 FX
    Audio Device: Aardvark DirectPRO 24/96 (ASIO)
    Operating System: Windows XP PRO Service Pack 2
    Vegas Version: 6.0d
    NOTE: The sound card is set at 16 bit and 44kHz and the audio is a 16 bit 44kHz wav file. I also tried an Mp3 audio file and had the same results.
    Danenew replied 20 years, 4 months ago 1 Member · 1 Reply
  • Danenew
    May 6, 2006 at 10:03 pm
    I figured it out. I needed to highlight the track/s or selection and use the Build Dynamic RAM Preview under Tools. – Works great!
