Activity Forums Creative Community Conversations Digital hits, usually green blocks, on renders
  • Digital hits, usually green blocks, on renders
    Posted by Bob Woodhead on August 5, 2019 at 11:01 pm
    Infrequently I’ll find digital hits in the shape of small rectangles, usually green, on rendered footage. They’ll be in a section of timeline, always play back in the same spot, can pause on them, export out, and have gone away when I clear cached renders. I would assume bad sectors on my external SSD, but not sure of a method to analyze the drive. SMART status doesn’t work on external USB, and Disk Utility doesn’t help.
    Suggestions?
    Oliver Peters replied 7 years ago 4 Members · 7 Replies
  • 7 Replies
  • Dom Silverio
    August 7, 2019 at 3:23 pm
    What kind of Mac and GPU are you using?
  • Bob Woodhead
    August 7, 2019 at 3:30 pm
    Late 2013 Mac Pro D700s
  • Dom Silverio
    August 7, 2019 at 3:49 pm
    Unfortunately, this is a design flaw on that Mac. During heavy CPU and GPU usage, the computer is unable to dissipate heat fast enough thus can cause random corruption. I highly recommend keeping renders in short bursts to prevent heat build-up.
  • Bob Woodhead
    August 7, 2019 at 4:29 pm
    Wow, I was sure it’d be a drive problem! I’ve got a utility that overrides the internal fan speed control, I wonder if there’s a utility to change the thresholds (the one I’ve got is just manual constant speeds).
  • Bob Zelin
    August 7, 2019 at 5:27 pm
  • Bob Woodhead
    August 10, 2019 at 2:53 pm
    Never ran across those articles, so thanks Bob.
    For anyone reading this, there is a utility called Macs Fan Control, and there is an option to select any of the sensor points and adjust thresholds & fan speed. It was evident from sensor readings that on my MP ’13 the GPU 2 sensor was much hotter than 1, so I just adjusted the threshold way down. If it’s heat related, that’ll fix that. 🙂
  • Oliver Peters
    August 18, 2019 at 9:47 pm
    I run into this constantly with Adobe apps (2013 MP, 8-core, D500). Usually when I have higher res media like 4K footage. I almost never have a problem with FCPX or Compressor. Resolve is so-so. Again more likely with higher res outputs. I also run Mac Fan Control cranked to max speed. It helps, but is not a cure.
    – Oliver
    Oliver Peters – oliverpeters.com
