Activity Forums Canon Cameras Digital Distortion Dropout
  • Blaise Douros
    September 1, 2017 at 5:23 pm
    If this is embedded in the video file (confirm by looking at it on different players, like VLC), then there is no specific plugin to repair it. If it’s a player error, then you might be able to get away with recompressing the file.
    You haven’t specified whether it’s just this frame, or if it’s continuous? If it’s continuous throughout the second half of the video, then I’m afraid there is no easy fix. It might be more practical to reshoot. If it’s just a few frames here and there, you could probably do some things to repair it.
    One thing you might try is the After Effects Wire Removal plugin. It’s designed to remove wires from flight rigs, but could easily be positioned at the ends of your distortion to blur it out with the surrounding pixels; the thinner the glitched pixels, the better.
  • Lisa Dunn
    September 1, 2017 at 8:34 pm
    Thanks for your response.
    Yes it is continuous. It starts two thirds in to a 2 hour filming session and remains there throughout. I’m wondering what caused it too?!
  • Blaise Douros
    September 5, 2017 at 4:40 pm
    It looks like a codec error, which would imply a glitch in the processor. Could even be a problem with the sensor. But without files to look at, and the camera to test with, I couldn’t tell you for sure. I would shoot tests with the camera to see if it returns.
