Activity Forums Apple Final Cut Pro Legacy digital desktop cinema preview query
  • digital desktop cinema preview query
    Posted by Accountclosed on March 17, 2006 at 4:04 pm
    under audio/video settingswhat is the difference between digital desktop cinema preview and digital desktop cinema preview raw? and what is digital desktop cinema preview raw acutally showing when selected?
    Sterling Noren replied 20 years, 5 months ago 2 Members · 1 Reply
  • Sterling Noren
    March 17, 2006 at 6:10 pm
    Its pretty clearly explained in the manual on page 217 (volume 1)
    Basically, the preview mode shows the video at its normal size unless it is larger than the monitor in which case it scales it down to fit the size of the monitor.
    In Raw mode it always shows the video at its true size with as little processing as possible, even if it is larger than the monitor…in which case you dont see all of the image.
    Generally you will want to use the “Digital Cinema Desktop Preview” mode if you have a dual-monitor setup and “Digital Cinema Desktop Preview – Main” on a Powerbook.
    Sterling Noren
    Owner/Writer/Producer/Editor
    WideWorld HD Productions
    Seattle, WA
