Activity Forums Apple Final Cut Pro Legacy Digital cutting (insert edit) on to tape via FCP
  • Digital cutting (insert edit) on to tape via FCP
    Posted by Aaron Jones on March 19, 2007 at 11:25 am
    Hi there, I use Avid to edit but I have been toying with the idea of using FCP and to tell you the truth I kinda like it.
    Now there is only one problem i can’t seem to find a solution for…
    In Avid I like to insert edit on to a striped tape for archive purposes, and though FCP can print to tape I cant find anywhere that allows me to tell it a frame accurate time code to start from, only on the fly out puts?
    Am I missing something simple?
    Thanks for your time
    Aaron
    Chris Borjis replied 19 years, 5 months ago 5 Members · 5 Replies
  • John Steventon
    March 19, 2007 at 12:25 pm
    Hey Aaron,
    Please forgive me if for some reason this option isn’t available on your system, but the equivalent you’re looking for is under Print to Video – ‘Edit to Tape’.
    This is pretty much the same as the Digitial Cut tool in Avid. Type in the timecode in the bottom left hand corner that you want the cut to start at, you wish to start the cut in at and have an in and an out marked on your sequence (as you already know I’m sure).
    Then, on the right hand bottom corner, above the timecode entry box (which you can leave blank) you find the icons to select video /audio etc for the insert.
    Click on the ‘Mastering Settings’ tab at the top of the window, and make sure the ‘Print’ drop down is set to ‘in to out’ and that you don’t have any of the Leader stuff set, or have any black set to record afterwards.
    Now, simply drag (but don’t let go yet) your sequence onto that window, and you’ll be presented with Insert, Assemble and Preview as your options – just drop the sequence onto the one you want (in this case, Insert) and it’ll work perfectly.
    Until you get that !*&&$$* annoying ‘Your edit only lasts one frame’ error…
    Like I said, this might not appear for you – maybe if you’re on DV? I don’t know – but this is how I cut out from FCP – I don’t think I’ve ever used Print to Video… (should I?).
    John
    John Steventon – Author of DJing for Dummies
    Success is merely a failiure to imagine more…
    G5 2.7Ghz, 4.5Gb ram, Blackmagic Decklink/multibridge, 5.6Tb Infortrend storage, FCP Studio 5.04, Makie MCU control, Yahama 5.1 surround, JVC DTV multi-format monitor, 2x23inch Apple monitors – and a partirdge on a pear tree.
  • Walter Biscardi
    March 19, 2007 at 12:26 pm
    [Luciddreama] “In Avid I like to insert edit on to a striped tape for archive purposes, and though FCP can print to tape I cant find anywhere that allows me to tell it a frame accurate time code to start from, only on the fly out puts?”
    Edit to Tape. Perform an Insert Edit. Accuracy depends on the VTR you are using, i.e. RS-422 controlled decks are generally frame accurate, firewire controlled decks are generally not.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Aaron Jones
    March 19, 2007 at 1:10 pm
    Aha… It all now makes perfect sense! D’Oh! I feel a fool. haha.
    Thanks John, thats all it took. Oh dear.
    Well at least I can now get on.. Wonderful stuff.
    Thanks Again
    and long live the cow!
    Aaron
  • Shane Ross
    March 19, 2007 at 2:12 pm
    Why not check out avid2fcp.com while your at it. It is a site dedicated to help Avid users switch to FCP.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Chris Borjis
    March 19, 2007 at 5:41 pm
    when I first learned of only being able to edit to tape in fcp, by actually
    dragging the sequence to the window I thought it was goofy as hell.
    But I’m used to it now.
