Activity Forums Avid Media Composer digital cut no audio
  • digital cut no audio
    Posted by Sherrie De leon on November 10, 2009 at 4:50 am
    I’m using Avid Xpress Pro on a dell dimension 8400. I can capture and playback audio on the Avid, but when I try a digital cut, only video comes out to tape. I’m using firewire out to mini dv or dvcam.
    Does anyone know a fix for this?
    Thanks.
    Sherrie De leon replied 16 years, 9 months ago 2 Members · 2 Replies
  • Jon Zanone
    November 11, 2009 at 2:07 pm
    Do you have your deck setup to accept firewire audio? Check your manual and the deck settings to be sure.
    An obvious question – do you have your audio tracks activated in the digital cut tool?
    Jon
    Be curious, not judgmental.
    Walt Whitman
  • Sherrie De leon
    November 11, 2009 at 2:30 pm
    I’m recording the digital cut using a Sony mini dv camera.
    From what I’ve seen on other forums, it may have something to do with the DV Output setting on Avid, but mine is not allowing me to check it off because I’m not using a camera recognized by Avid.
    Any thoughts?
