Activity Forums Avid Media Composer Digital Cut fails without error message….?
  • Digital Cut fails without error message….?
    Posted by Fabio De la rocha on September 16, 2008 at 1:45 pm
    I’m trying to output DV onto my HVX200 from MC 3. I’ve tried several times now and each time I get to around ten minutes (precise point is different every time) and it just stops. There’s no error message or anything, it just gives up.
    Any help appreciated as I’m on a deadline (as ever!)
    Dell Precision T3400/Core2duo 2.66GHz/4GB/Nvidia Quadro FX 1700 Running Avid Media Composer 3.0
    Dell Precision M90 Core2duo 2.33GHz/4GB/Nvidia Quadro FX 2500M Running Avid Media Composer 3.0
    Dante Torres replied 17 years, 11 months ago 3 Members · 4 Replies
  • Grinner Hester
    September 16, 2008 at 1:50 pm
    Is the whole tape striped?
    don’t miss your deadline. crash record it if ya have to.
  • Fabio De la rocha
    September 16, 2008 at 1:54 pm
    Awesome speedy reply, thanks Grin.
    I am crash recording. Is there a way to stripe a tape in the HVX200 that you know of?
  • Grinner Hester
    September 16, 2008 at 8:10 pm
    off the top of my head, I dont recall how to set your tc on it but if you just record through the entire tape, it’ll have a constant control track you can lay off to.
  • Dante Torres
    September 18, 2008 at 6:44 am
    have you solved the problem?
    have you tried disconnecting any monitor from the camera? this i believe, intermittently cause signal conflicts with the 1394 connection when dubbing out — happened to me a number of times before.
    goodluck!
