Activity › Forums › Adobe After Effects › Digital counter
Digital counter
Posted by Daniel Neutzsky-wulff on January 30, 2013 at 11:01 pmHi,
I need to make a digital counter.
Something like this:
HH:MM:SS
32:22:43
It’s for a movie watching marathon and I need to show how long the contestants have been watching.
I’ve tried different methods, but I find it very hard to control the timer. For some reason I can’t go above 24 hours?
Best regards,
DanielJohn Cuevas replied 13 years, 7 months ago 3 Members · 3 Replies -
Angelo Lorenzo
January 30, 2013 at 11:18 pmWhat scripts have you tried? Seems as simple to me as adding an offset like HH+24 once you get past 24 hours.
It’s be nice to see what you’re working with. I don’t have any pre-made scrips for that offhand.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks -
January 30, 2013 at 11:47 pmI’m fairly new to this. I simply added a solid and added the effect: Text>Numbers
I’ve been altering the look and so forth, but I still can’t get full control of the timecode.
John Cuevas
January 31, 2013 at 12:36 pmHere’s an expression I modified from the book After Effects Expressions
If you are unfamiliar with expressions, what you want to do is create a new text layer (shift+cntl+alt+T) and twirl open the properties to reveal the source text. Alt+click the Source Text stopwatch and paste this expression:
var startingHour = 10;
var startingMinute = 59;
var startingSecond = 4;
var seconds = Math.floor(time) + startingSecond;
var minutes = Math.floor(seconds / 60) + startingMinute;
var hours = Math.floor(minutes/60) +startingHour;
var secondsAsPartsOfAMinute = Math.floor(seconds % 60);
var minutesPerHour=Math.floor(minutes % 60);
function addZeros(rawNumber)
if (rawNumber < 10) return "0" + rawNumber;
return "" + rawNumber;
addZeros(hours)+ ":" + addZeros(minutesPerHour) + ":" + addZeros(secondsAsPartsOfAMinute);With this expression you can set your starting time by chaning the “starting” variables. Just in case anything was unclear, here’s my work file: 5347_timer.aep.zip
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb.
