Activity Forums Apple Final Cut Pro Legacy Digital Camera MPG Audio
  • Digital Camera MPG Audio
    Posted by Don Mousseau on February 11, 2006 at 2:51 pm
    I have a ton of footage taken with a Sony and Canon Digital Cam. The movie format is MPG NTSC. When I import into Final Cut there is no audio hwever when I play the clips in QT the audio is there. I tried exporting with QT Pro and the audio settings are faded out. SO far the only way I have found to recover the audio is to import the clips into Cakewalk Pro Audio then export the audio clips seperately. Is there any other converter out there that will resave the movie data in a Final Cut friendly format? Preferably a MAC OSX app. Thanks in advance for any info you may have.
    Jerry Hofmann replied 20 years, 7 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    February 12, 2006 at 4:32 pm
    Search this forum on the word “demux” and you’ll get your problem fixed…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
