Activity Forums Audio Digital camera audio input levels?
  • Digital camera audio input levels?
    Posted by Bob Mark on September 15, 2021 at 5:07 pm
    Hi everybody. What recording level do you set for tone level on digital cameras for dialog? i have seen recommendations from -20db to -6 db Thanks
    Bob Mark replied 5 years ago 3 Members · 6 Replies
  • Bret Hampton
    September 15, 2021 at 6:12 pm
    -20db is normal for video/audio.
    Music folks often like -14.
    However -20 is most common. Just be consistent
  • Ty Ford
    September 15, 2021 at 7:40 pm
    Hello Bob. Welcome to the Cow Audio Forum.
    I’m a -20 sort of guy. Others may differ as Bret says.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
  • Bob Mark
    September 15, 2021 at 10:54 pm
    Hi Bret thanks for that info. That’s what I had been using but a camera man just asked ” do you want -6 or -20″ Thanks for that!
  • Bob Mark
    September 15, 2021 at 10:56 pm
    Hi Ty thanks for welcome! Having you say -20 really helps to validate what I have been using. Thank you.!
  • Ty Ford
    September 16, 2021 at 12:22 am
    I guess it depends somewhat on whether or not you’re using a good limiter. I use Sound Devices mixers. They all have pretty nice limiters. As such I might squink my level up to a little higher if I’m pretty safe with the idea that no one will be screaming. And this doesn’t mean Peaks at -20. With tone at -20, your peaks will be above that.
  • Bob Mark
    September 17, 2021 at 12:22 am
    Once again, thank you for that info!
