Activity › Forums › AJA Video Systems › digital artifacts
  • digital artifacts
    Posted by Lincoln on June 6, 2005 at 6:46 am
    Having a problem with the Kona2.
    Any footage we capture has tiny (1pixel) random pink artifacts.
    This happens regardless of the source (SD or HD).
    The location changes as we flick between the same frames so its most likely an out put issue. Anyone else had and fixed the problem?
    Cheers,
    Linc
    Lincoln replied 21 years, 3 months ago 2 Members · 5 Replies
  • Walter Biscardi
    June 6, 2005 at 1:08 pm
    Can you give us more system details? Computer, OS, decks, monitor, etc…
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Lincoln
    June 6, 2005 at 11:29 pm
    dual 2 gig G5
    10.4.1
    FCP 5
    Kona2/K-box
    PAL digibeta DVWM2000P
    J-H3
    Sony LMD monitor
    Issue occurred under 10.3.9/FCP HD/and previous kona drivers.
    Doesn’t occur with Footage captured at 1080i
    all captured footage is actually ok as I’ve checked it on our decklink system which outputs without the artifacts.
  • Lincoln
    June 7, 2005 at 12:43 am
    ok after much testing the problem occurs whenever the primary format is set to 625i25 if it’s set to 1080i the artifacting doesn’t occur.
    Solutions/thoughts?
  • Lincoln
    June 7, 2005 at 12:45 am
    also occurs at 720P but interestingly the artifacts are blue not red as with 625i
  • Lincoln
    June 7, 2005 at 2:10 am
    reseated kona2 board and kbox cables. Seems to be fixed for now.
