Activity › Forums › Adobe After Effects › Digital artifact effect
  • Digital artifact effect
    Posted by Adam Ghering on August 12, 2009 at 2:54 am
    I am trying to create a digital artifact effect in after effects. I coul probably do it with native AE plugins but I have no idea which ones or which combinations. The biggest problem is that I have no reference. I figured there would be a plugin out there for this but they only do television noise which isn’t what i am after. I am trying to recreate the digital signal artifacting that comes with a weak or corrupt signal. example:
    https://www.cesta.cz/photos/tandt/film%20series%202005/LOSING_TOUCH.jpg
    If anyone can point me in the right direction I would appreciate it….if I could just get a couple seconds of reference I could probably reproduce it.
    Scott Roberts replied 17 years, 1 month ago 3 Members · 2 Replies
  • David Johnson
    August 12, 2009 at 11:29 am
    I’m not able to write a detailed response right now but some things to consider …
    A combination of native AE tools like fractal noise and the ability to lower video resolution can achieve this effect easily.
    There are several third-party plugins that do this effect … not sure I recall specifics, but you might look at DigiEffects.
    A search of past COW posts will provide plenty of details on those two options and probably others.
  • Scott Roberts
    August 15, 2009 at 10:06 pm
