Activity › Forums › Apple Final Cut Pro Legacy › Digibeta to DVCProHD via AJ-HD1200 or 1400?
  • Digibeta to DVCProHD via AJ-HD1200 or 1400?
    Posted by John Burgan on April 18, 2009 at 12:10 pm
    Working on an archival project, shooting new material on the HVX900 (720p)
    A lot of the archive is on Digibeta. Is it possible to upres Digibeta to DVCProHD (720p) through the AJ-HD1200 or 1400 in one pass? This would be SDI in and firewire out E-E, capturing directly into FCP?
    John Burgan replied 17 years, 5 months ago 4 Members · 4 Replies
  • Rafael Amador
    April 18, 2009 at 1:23 pm
    Hi John,
    I haven’t got a AJ-HD1200/1400, but I’ve bee reading the specs in the PANASONIC web site.
    I don’t see the the possibility o ingesting SD through SDI and up-convert on recording.
    The brochures talk about up-scaling when playing SD DVPro tapes to DVCProHD.
    Any way I may be wrong.
    A capture card (AJA, BM) would do the job.
    rafael
    http://www.nagavideo.com
  • Arnie Schlissel
    April 18, 2009 at 2:15 pm
    I don’t think that these decks play digiBeta tapes.
    You can buy a Kona 3 or Io HD, then rent a digiBeta deck and use the Kona or Io to upconvert.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Shane Ross
    April 18, 2009 at 4:50 pm
    What they said…the decks don’t upconvert. YOu need to go through the AJA hardware or MXO2.
    Shane
  • John Burgan
    April 19, 2009 at 11:25 pm
    Thanks for this, folks. Just for the record, I have access to a Digibeta as a source player, wasn’t suggesting that the Panasonic would accept the Digibeta tapes.
