Activity › Forums › Apple Final Cut Pro Legacy › Digibeta audio bitrate
  • Digibeta audio bitrate
    Posted by Anne Murray on July 17, 2007 at 8:26 pm
    I’m laying off a show to digibeta this week & the mixer asked me what bit rate to use for a Digibeta. I know dbeta is natively 20bit, so if I use a 16bit 48khz file, will anyone be able to tell the difference between a 16bit and 24bit output? I’d read that 24bits get dithered down to 20bit, often with some audio artifacts and errrors.
    I’m using FCP.
    Michael Gissing replied 19 years, 2 months ago 3 Members · 2 Replies
  • Chris Borjis
    July 17, 2007 at 8:51 pm
    I do everything at 16-bit 48khz to Digibeta and it works.
    Its not broken so I won’t fix it. 🙂
  • Michael Gissing
    July 18, 2007 at 2:05 am
    The 24 bit gets truncated to 20 bits unless you pre dither it. I don’t think the digi beta does dithering. Don’t fret about it.
    Some dithering and noise shaping can create problems if you don’t know what you are doing. I have not heard any problems dropping a 24 bit file and laying off to digi beta and we are a sound post with FCP facility. Similarly 16 bit files work fine as well. A typical broadcast sound track won’t have anything like the dynamic range that would need a 24 bit file anyway.
