Activity › Forums › Apple Final Cut Pro Legacy › Digi Beta question
  • Digi Beta question
    Posted by Roli Rivelino on January 28, 2011 at 10:14 am
    I’m cutting a multi format project, from EX to, 35mm to mini dv through to Digi beta.
    My sequence is lead by the EX footage so it’s 1080 35 mbr 25 fps
    I’m just wondering with the Digi Beta stuff, when it gets converted is there anything that I have to look out for/ask the production facility?
    Many thanks.
    https://www.rolirivelino.com/
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Shane Ross replied 15 years, 8 months ago 3 Members · 4 Replies
  • Shane Ross
    January 28, 2011 at 10:22 am
    First, you need to figure out what settings you want. HD or SD. What is your final output going to be? That pretty much dictates the workflow. If it is going to be SD, then use an SD sequence and capture the digibeta as DV50 (DVCPRO 50), or ProRes NTSC. If it is going to be HD, then see if they have the hardware capture card that will upconvert the footage to HD…and choose either PILLARBOX where you see the entire image, but with black bars on the side, or if you want it to chop off the top and bottom of the screen and make it fill the 16:9 frame.
    Shane
  • Roli Rivelino
    January 28, 2011 at 11:10 am
    Decisions, decisions.
    Many thanks Shane.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Bouke Vahl
    January 28, 2011 at 2:06 pm
    Not really.
    he’s working in 25 fps.
    So Prores NTSC is a bit silly, Prores @ 25 fps is more logical.
    (And note that NTSC is not the correct term, since it’s not a composit signal, but anyways…)
    In 25 fps it is common to have full height anamorphic 16:9.
    So a conversion to HD should be full frame. Black bars are never a good idea if the source is 16:9
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Shane Ross
    January 28, 2011 at 2:39 pm
    What he said. I didn’t notice the PAL settings.
    Shane
