Activity Forums Avid Media Composer DIG VDM Overrun
  • DIG VDM Overrun
    Posted by Neil J on June 20, 2005 at 1:45 pm
    Using an Adrenaline V 1.6 PAL I am trying to batch capture SDi 1:1 and am repeatedly getting the error message ‘dig vdm overrun’.
    I can capture to any other resolution(but don’t want to as the project is an ongoing series all created @1:1 for International distribution).
    I have had this error occasionally before and hitting try again or skipping the clip and returning to the offending clip later always worked. But today no joy.
    Done the usual dump of data bases, re-booted, checked cables etc…
    Any ideas?
    Kevin Thomas replied 18 years, 2 months ago 3 Members · 3 Replies
  • Bill Stephan
    June 20, 2005 at 7:54 pm
    An overrun during capture means that the storage is not taking away the data created by digiting fast enough. Are your drives speced for uncompressed capture? If the drives work correctly only on compressed resolutions, that indicates that your drives and/or the data bus are not fast enough.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Neil J
    June 21, 2005 at 8:20 am
    The drives are striped LVDs and have been happily digitising 1:1 since before Xmas, so i can’t see that that is now the problem.
    Any other theories?
  • Kevin Thomas
    July 14, 2008 at 1:17 pm
    You may want to try deleting the Directories…(as I’m doing now)
    Exit Avid
    Navigate to the drive
    Open the media folder (omfi or mxf)
    If MXF, open each of the folders within
    Find the .MSM files and drag them to the bin
    Empty the bin and close the folders
    Launch Avid and allow it to rebuild the directories
    Should clear up the issue
    Another thing is that if you’re drives are nearly
    full, you could have some speed issues.
    Good luck!
    Life. Style. Never a Shortcut.
    No one knows everything, everyone knows something and sometimes we can’t remember
    anything… that when we go to the COW!
