Activity Forums Adobe Illustrator Diffusion on a flat surface
  • Diffusion on a flat surface
    Posted by Serge Leone on May 5, 2010 at 5:41 pm
    Hello,
    First off – i want to recreate a surface i saw on a flash app.
    It´s a virtual clone of a drum-machine.
    I don´t really know how they did the surface.
    I thought with a gradient mesh and very subtle changings – did not work out…
    same goes to 3d diffusion since its flat
    anyone got any clues leading me in some direction?
    thanks in advance
    Serge Leone replied 16 years, 4 months ago 2 Members · 2 Replies
  • Vincent Rosati
    May 5, 2010 at 7:29 pm
    Maybe something like this:
    https://www.newinelabs.com/rosati/tutorials/illustrator_metal_panel_cs2.ai
    It’s a radial gradient with a raster brushed metal tile on top. The edges are opacity mask gradients, accessed in the Transparency drop-down menu.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Serge Leone
    May 6, 2010 at 2:07 pm
    Wow, just wow 🙂
    Thank you very much for your fast reply, even more for the supplied file.
    good karma
    greetings, mike
