Activity Forums Boris FX diffuse the dark areas – BCC AVX
  • diffuse the dark areas – BCC AVX
    Posted by Brian Williams on April 25, 2006 at 6:00 pm
    I’m looking for a particular film like look and just want to diffuse the dark areas a little. I’m useing BCC AVX on an AVID adrenaline. I don’t want to cut mattes etc. to do this. Is there a way to reverse the glow thresholds to work on the blacks instead of highlights?
    Brian
    Peter Mcauley replied 20 years, 3 months ago 2 Members · 1 Reply
  • Peter Mcauley
    May 5, 2006 at 7:37 pm
    You can use the built-in pixelchooser in the Glow filter to matte out the areas of interest and the filter will only apply to that portion of the clip. This should generate the desired effect.
    Or you could use the Film Process filter and select the shadow diffusion preset from the preset pop-up. It’s a slightly different effect but worth a look nonetheless.
    I hope this helps.
    Peter.
