Activity Forums Apple Final Cut Pro Legacy Difficulty meeting MPEG-2 specs for TV channel using Compressor
  • Difficulty meeting MPEG-2 specs for TV channel using Compressor
    Posted by Alan Okey on October 15, 2009 at 9:54 pm
    One of my clients was recently given the option to submit his TV spots as MPEG-2 files. I was unable to create files with the proper specs using Compressor, as it doesn’t seem to have granular control over chroma sampling in MPEG-2 files. The required file specs are listed below:
    Video Specifications
    Encoding . . . MPEG-2
    Preferred. . . 18Mb/s
    Scanning. . . . 480 60i (upper field first)
    Pixel Aspect Ratio. . . 0.9
    Aspect Ratio. . . . 4:3
    Chroma. . . . 4:2:2 (MP@ML) (720*512)
    GOP. . . . All Allowed, IBBP preferred
    Frames per second. . . . 29.97 (NTSC)
    Stream Type . . . Program Stream
    Audio – MPEG-1, Layer 2 . . . 384Kb/s Stereo
    Audio – Dolby AC3 . . . N/A
    Digital Audio Level. . . –20dBfs
    Luminance Level Max. . . . 100 IRE
    Chroma Level Max. . . . 120 IRE
    Setup level. . . 7.5 IRE
    Timecode. . . Not Used
    I was unable to create an MPEG-2 file with 4:2:2 chroma sampling @ 720×512. Is it possible to do this with Compressor? If not, can anyone recommend software that will generate files that meet these specs?
    Thanks in advance.
    Melanie Smith replied 16 years, 4 months ago 6 Members · 5 Replies
  • Walter Biscardi
    October 15, 2009 at 10:03 pm
    Haven’t had to do this, but you might try Telestream Episode or Episode Pro. You can do a free sample of up to 30 seconds I believe without paying for the software to see if you can get the specs you need.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Craig Russillroy
    October 16, 2009 at 5:22 am
    Seeing it is a color space of 422 you need episode – compressor can only do 420 mpef – episode is great as it intergrates into compressor – I know this cause I spent 5 years in a company called Adstream – we digitally delivered over a million tvc
    MINTedit
    London, England
    Mac Pro – 8gig ram – FCS 3 – CS4 – Cinema 4D
    Film, Edit and Deliver
  • Rafael Amador
    October 16, 2009 at 6:26 am
    Right.
    The only options for output 422 MPEG-2 in FCS are for XDCAM.
    Rafael
    http://www.nagavideo.com
  • Hanabal Khaing
    January 29, 2010 at 7:29 pm
    I’m not sure about the size 720×512, but I have seen a check box in compressor that has YUV 4:2:2 color encoding (Not for DVD use).
    Documentation from Apple for Compressor 3.
    https://documentation.apple.com/en/compressor/usermanual/index.html#chapter=18%26section=4%26tasks=true
    YUV 4:2:2 Color encoding (Not for DVD use): Select this checkbox to enable 4:2:2 color encoding. This option is supported in the creation of MPEG-2 elementary, program, and transport streams, but it is only available when the Stream Usage pop-up menu is set to Generic.
    I think you should be fine if you set the size and export to uncompressed 10 bit 4:2:2 and then use that in compressor.
    Powermac G5 2.5GHz Quad Core
  • Melanie Smith
    April 22, 2010 at 10:24 pm
    I am having a similar issue, but don’t want to pony up the cash for new compression software. I have cleaner 6.5.1 and compressor 3. it seems that the apple spec’s claim you have 4:2:2 control in compressor’s mpeg 2 format settings but I dont see it enabled. and when i try to use cleaner to output, though i can set the chroma, I can’t get the mpeg 2 format in full HD (1920×1080) to work with the mpeg 2 size limitations – I get a “image size not divisible by 16” error. anyone know of a work around? I’m trying to export for DGfastchannel and the chroma level is the only hiccup i seem to be running into.
    thx!
