Activity › Forums › Adobe After Effects › difficult Keying
  • difficult Keying
    Posted by Stephen Cook on June 25, 2006 at 7:51 pm
    I have some footage that I have been working on for a freind. I am using the college computer as they have all the software I need to edit the film. I am using After Effects 6.5 and here is my problem.
    I have used keylight to key out most of the green. (BTW I know that the green background is not the perfect green screen cloth to use it was not my choice) I followed the tutorial on making super tight junk mattes by Aharon Rabinowitz that works well. However I am getting artifacts that appear on the actress as bright spots that were not there before keyeing. Also the actor has feathers that wind up getting lost after keying. If you look really close you can see some sort of halo around the keyed image. Its not green either so it doesn’t get keyed. I know that perhaps some of the green on the costume that gets removed will cause the actor to have an off color around the edges which can be blured or dealt with. My main issue is with the halo around the actress. The spots between her arms and body also show up as blueish areas.
    If anyone has any good ways to correct this I am open to suggestion and it would speed up my workflow.
    I am working on a fan film for Star Wars. I will be happy to send footage to anyone that is willing to help me get movingforward.
    Here are links to the images:
    https://www.ablephone.com/stuff/SWoriginalshot.jpg
    https://www.ablephone.com/stuff/SWkeyedshot.jpg
    -= Stephen C. =-
    John Cuevas replied 20 years, 3 months ago 4 Members · 4 Replies
  • Justin Productions
    June 25, 2006 at 9:41 pm
    If it isn’t too big, send it to me at Tangerin01@gmail.com, I’ll have it a look.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Walter Biscardi
    June 25, 2006 at 9:50 pm
    Did you shoot this on DV? Some of this sounds like DV Compression which is compressed 5:1 and causes all kinds of issues when trying to pull a key.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
    June 25, 2006 at 11:44 pm
    Hey Walter,
    From your opinion, what would be the best format to pull out a good key? 4:4:4? Wich type of cam’?
    Thx.
    Justin Productions
    Adobe After Effects 6.5 Profesionnal
  • John Cuevas
    June 26, 2006 at 2:09 pm
    Was just fiddling around with it, and I found it was easier to key the red out, then the green. Did that, then put the layer on top as a inverted alpha matte and got better results…
    Johnny Cuevas, Editor
    http://www.ckandco.net
