Differing render results using AE & Encoder
When I render .flv files, I get differing results using After Effects CS5 (version 10.0.2.4) then when I use Adobe Media Encoder CS5 (version 5.0.1.0). The colors in the Encoder version (right picture) do not seem to match was I originally see in AE and are more saturated:
With both programs I use the “On2 VP6” codec and “VBR” set to the same bitrate with “Quality” set to “Best”. Yes, we are using a Linearize Working space. My “Project Settings” look like this:
We shoot with a Sony XDCAM at 1920×1080 HD422 25P – the imported .mxf is interpreted as HDTV (Rec. 709) Y’CbCr. Are we doing something wrong here?
