Activity › Forums › Apple Final Cut Pro Legacy › different sample rate then sequense
  • different sample rate then sequense
    Posted by Erez Gudes on March 20, 2006 at 4:57 am
    When I capture video and the sample rate on the tape is different then the sequence settings, I get a warning “the sample rate on your media files does not match the sample rate on the source tape. This may cause audio offsync” Is there any way that final cut can tell you this before you go through a long capture? thanks
    Erez Gudes replied 20 years, 6 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    March 20, 2006 at 1:50 pm
    I’m afraid it has to analyze a captured file first. It may or may not be a problem though. Are the files out of sync? if not, you really don’t have a problem, right?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Erez Gudes
    March 20, 2006 at 4:44 pm
    no. I’ve gotten these warnings many times over time, but the audio has never been out of sync. I’m just waiting for the day it does. Thanks!
  • Erez Gudes
