Activity Forums Adobe After Effects Different pixel dimension when/after rendering
  • Different pixel dimension when/after rendering
    Posted by Benedict Hein on November 21, 2018 at 9:13 am
    Hi Folks,
    I’ve got an animated christmas card in 1280×589. When exporting, either with AE directly or via media encoder,
    i am getting 588 in height instaed of my comp size 589. Media Encoder even has 588px in the export settings, which I am not allowed to edit, even tho my comp size is different. Any ideas?
    Regards
    Ben
    Jeff Pulera replied 7 years, 9 months ago 4 Members · 4 Replies
  • Tero Ahlfors
    November 21, 2018 at 9:32 am
    The format you’re trying to export to requires the width and height to be divisible by two so it’s automatically rounded. The best practice would be to work in a resolution that doesn’t have odd values.
  • Benedict Hein
    November 21, 2018 at 9:36 am
    Thank you for the answer.
    Customer wants it embedded on their website, so the dimensions are fixed.
    Is there any format supporting these kind of values?
  • Bouke Vahl
    November 21, 2018 at 10:30 am
    There is encoded format and display format. Display can be anything, render cannot.
    Render to the closest value and be done with it.
    Bouke
    http://www.videotoolshed.com
  • Jeff Pulera
    November 27, 2018 at 9:50 pm
    Compression takes place in blocks of pixels, like 8 or 16 or 64. Numbers divisible by 8 basically. You can’t just dream up odd-number random dimensions and make it work, sorry, it breaks the encoder.
    Jeff
