Activity Forums Apple Final Cut Pro Different image sizes?
  • Different image sizes?
    Posted by Jon Smitherton on October 31, 2011 at 9:01 pm
    Hi
    I’m doing a mashup of youtube videos…
    I’ve downloaded the youtube videos as flv’s then transcoded them in MPEG Streamclip to Prores LT…however they are different sizes. I imported them as optimized media…however they are not transcoding…is this to do with different frame sizes?
    Cheers,
    Jon
    Jon Smitherton replied 14 years, 10 months ago 2 Members · 5 Replies
  • Jon Smitherton
    November 1, 2011 at 7:25 am
    For instance non PAL or NTSC SD or HD sizes…
  • Simon Ubsdell
    November 1, 2011 at 11:14 am
    [jon smitherton] ” transcoded them in MPEG Streamclip to Prores LT…however they are different sizes. I imported them as optimized media…however they are not transcoding”
    If you’ve already transcoded with MPEG Streamclip to ProRes them they are already optimized for FCPX and don’t need further transcoding – so FCPX won’t do anything further with them.
    Are you having problems with resizing your clips?
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
  • Jon Smitherton
    November 2, 2011 at 12:43 am
    Hi Simon
    No, I’m having trouble importing the clips..was thinking it is non PAL or NTSC sizes…like 720 x 480 etc…
    either that or FCPX isn’t liking Prores LT…
    Cheers,
    Jon
  • Simon Ubsdell
    November 2, 2011 at 4:59 pm
    [jon smitherton] “‘m having trouble importing the clips..was thinking it is non PAL or NTSC sizes…like 720 x 480 etc…
    either that or FCPX isn’t liking Prores LT…”
    I ran a test of your workflow – FLV to MPEG Streamclip, export ProResLT (640×360), import into FCPX (copying file to Events folder). Clip plays fine in the Browser, and when edited into a 1080 timeline.
    I’d suspect that it might be how you are exporting from MPEG Streamclip … could you let use know your export settings?
    Simon Ubsdell
  • Jon Smitherton
    November 2, 2011 at 7:33 pm
    Hi Simon
    Thanks for your help – FCPX needed its preferences deleted… thanks to preference manager!
    Cheers,
    Jon
